Zum Hauptinhalt wechseln
Blackstone Cascade Pro Fan Replacement
Was du brauchst
  1. Blackstone Cascade Pro Fan Replacement, Fan: Schritt 1, Bild 1 von 3 Blackstone Cascade Pro Fan Replacement, Fan: Schritt 1, Bild 2 von 3 Blackstone Cascade Pro Fan Replacement, Fan: Schritt 1, Bild 3 von 3
    • Remove the four screws surrounding the back of the Blackstone fan using a Phillips #00 screwdriver.
    • Remove the cover at the back of the fan.
  2. Blackstone Cascade Pro Fan Replacement: Schritt 2, Bild 1 von 2 Blackstone Cascade Pro Fan Replacement: Schritt 2, Bild 2 von 2
    • Remove the diamond cover at the top of the fan.
    • The diamond cover will be connected to a set of wires to the fan. Simply place the cover to the side for the rest of the repair.
  3. Blackstone Cascade Pro Fan Replacement: Schritt 3, Bild 1 von 3 Blackstone Cascade Pro Fan Replacement: Schritt 3, Bild 2 von 3 Blackstone Cascade Pro Fan Replacement: Schritt 3, Bild 3 von 3
    • Remove the two screws that are holding the spherical cover shielding the main fan using a Phillips #00 screwdriver.
    • Remove the spherical cover surrounding the main fan.
  4. Blackstone Cascade Pro Fan Replacement: Schritt 4, Bild 1 von 2 Blackstone Cascade Pro Fan Replacement: Schritt 4, Bild 2 von 2
    • On the opposite side there will be a cover identical to the one removed in the previous step.
    • Twist the main fan to remove the cover on the opposite side.
  5. Blackstone Cascade Pro Fan Replacement: Schritt 5, Bild 1 von 3 Blackstone Cascade Pro Fan Replacement: Schritt 5, Bild 2 von 3 Blackstone Cascade Pro Fan Replacement: Schritt 5, Bild 3 von 3
    • Using the socket wrench, and a size 10 shallow socket, remove the hexagon screw at the center of the main fan.
    • Pull out the main fan.
    • Depending on the age of your fan, it may require more strength to pull it out. Be careful to not use too much force.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
York University, Team P-1, O'Regan Winter 2024 Mitglied von York University, Team P-1, O'Regan Winter 2024
YORK-O'REGAN-W24SPG1
1 Mitglied
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 293
