Einleitung
This guide will show you several blade removing techniques for when the blades are stuck somewhere on the motor of your Ninja Master Prep QB900B.
Be sure to have a tough cloth or a cut resistant glove on hand for the repair. In addition, make sure to turn off the device and unplug from the power outlet before beginning this repair.
Was du brauchst
To remove the blades from each other, twist both blades in opposite directions and pull.
To remove the blades from the cup. Firmly grasp the bottom of the cup.
Pull upward as shown on the top of the blades.
To remove the blades from the motor, firmly grasp the motor top.
Next. Take a cloth or cut-resistant glove and grasp the blades.
Now twist both ends in opposite directions to separate.
