Zum Hauptinhalt wechseln
Blade Removal Technique
Was du brauchst
  1. Blade Removal Technique, Blade Removal Technique: Schritt 1, Bild 1 von 1
    • To remove the blades from each other, twist both blades in opposite directions and pull.
    • Be cautious, the blades are sharp.
  2. Blade Removal Technique: Schritt 2, Bild 1 von 1
    • To remove the blades from the cup. Firmly grasp the bottom of the cup.
    • Be careful when you are doing this next step.
    • Pull upward as shown on the top of the blades.
  3. Blade Removal Technique: Schritt 3, Bild 1 von 1
    • To remove the blades from the motor, firmly grasp the motor top.
    • Next. Take a cloth or cut-resistant glove and grasp the blades.
    • Be careful during this next step.
    • Now twist both ends in opposite directions to separate.
Ziellinie
Kamal Taha
679 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 1-3, Sullivan Fall 2015 Mitglied von USF Tampa, Team 1-3, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G3
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 8
Insgesamt: 960
