Zum Hauptinhalt wechseln
Blu Dash 5.0 Dual SIM Back Camera Replacement
Was du brauchst
  1. Blu Dash 5.0 Dual SIM Back Camera Replacement, Back Camera: Schritt 1, Bild 1 von 2 Blu Dash 5.0 Dual SIM Back Camera Replacement, Back Camera: Schritt 1, Bild 2 von 2
    • Make sure device is disconnected and turned off.
    • Locate the groove on the bottom left corner of the back of the phone.
    • Insert the plastic opening tool into the groove and pry it open.
    • Lift the back cover of the phone using your hands.
  2. Blu Dash 5.0 Dual SIM Back Camera Replacement: Schritt 2, Bild 1 von 1
    • Pry the battery out using the plastic opening tool.
  3. Blu Dash 5.0 Dual SIM Back Camera Replacement: Schritt 3, Bild 1 von 1
    • Remove the 12 screws on the back panel using a J000 screwdriver.
    • Red circles correspond to the screw holes holding 3.5 mm length Phillips screws.
    • Orange circles correspond to the screw holes holding 2.5 mm length Phillips screws.
  4. Blu Dash 5.0 Dual SIM Back Camera Replacement: Schritt 4, Bild 1 von 3 Blu Dash 5.0 Dual SIM Back Camera Replacement: Schritt 4, Bild 2 von 3 Blu Dash 5.0 Dual SIM Back Camera Replacement: Schritt 4, Bild 3 von 3
    • Peel off the back panel with your hand.
    • Remove the back panel slowly to avoid breaking it.
  5. Blu Dash 5.0 Dual SIM Back Camera Replacement: Schritt 5, Bild 1 von 3 Blu Dash 5.0 Dual SIM Back Camera Replacement: Schritt 5, Bild 2 von 3 Blu Dash 5.0 Dual SIM Back Camera Replacement: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Flip up the ZIF flap using the spudger.
    • Gently remove the ribbon cable with tweezers.
    • The ribbon cable is sensitve and needs to be removed carefully to insure its integrity.
    • Remove the back camera using tweezers.
Abschluss
Mukish Kumar Munyady
201 Reputation
2 Anleitungen geschrieben
IUPUI, Team 1-1, Baechle Spring 2017 Mitglied von IUPUI, Team 1-1, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G1
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 381
