Einleitung
Be prepared with the tools listed and also be cautious while going through the steps in this guide as the phone components are quite fragile.
Was du brauchst
Locate the groove on the bottom left corner of the back of the phone.
Insert the plastic opening tool into the groove and pry it open.
Lift the back cover of the phone using your hands.
Remove the 12 screws on the back panel using a J000 screwdriver.
Red circles correspond to the screw holes holding 3.5 mm length Phillips screws.
Orange circles correspond to the screw holes holding 2.5 mm length Phillips screws.
