Einleitung
Be prepared with the tools that are listed and be cautious while going through the steps as some of the components maybe fragile.
Was du brauchst
Locate the groove at the bottom left corner of the phone.
Insert the plastic opening tool in the groove and pry it open.
Lift the back cover of the phone using your hands.
Remove the 12 screws located at the back panel of the phone using a J000 screwdriver.
The red circles are screw holes that hold the 3.5mm length Phillips screw.
The orange circles are screw holes that hold the 2.5mm length Phillips screw.
Unscrew the 2.5mm screws from the circuit board holding the speaker at the bottom of the phone.
