Einleitung
Warning: If the battery is swollen or bulging it is dangerous to remove and is at risk of a chemical fire. Puncturing the battery will cause a chemical fire. Chemical fires cannot be put out by conventional methods ie water.
Was du brauchst
Using a Phillips #000 screwdriver, remove the 3mm screws. Be sure to do this for the top and bottom of the phone.
Remove SIM card tray with paperclip or SIM card tray removal tool.
Push down on the phone beside the camera and up on the backplate with your thumbs to remove the back plate. Remove adhesive if necessary.
Place the plastic opening tool in the highlighted indent, and push up on the battery to remove it.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
i need to buy a replacement battery for this phone but i don’t know which one to get. please help
