Zum Hauptinhalt wechseln
Blu Grand M2 Power Button Replacement
Was du brauchst
  1. Blu Grand M2  Power Button Replacement, Power Button: Schritt 1, Bild 1 von 1
    • Using a T2 Torx Screwdriver, remove the two screws from the bottom edge of the phone.
  2. Blu Grand M2  Power Button Replacement: Schritt 2, Bild 1 von 2 Blu Grand M2  Power Button Replacement: Schritt 2, Bild 2 von 2
    • Apply the suction tool to the back panel near the bottom edge.
    • Carefully slide the device pick between the back panel and bottom edge.
    • Insert the opening tool into the gap created by the device pick.
    • While holding the suction tool, use the opening tool to gently pry the back panel off.
    • Be Cautious to not damage the phone display and or the inside components while using the pry tool and suction tool.
  3. Blu Grand M2  Power Button Replacement: Schritt 3, Bild 1 von 1
    • Take the end of the opening tool and push the old power button out of its socket.
    • Remove the old power button.
  4. Blu Grand M2  Power Button Replacement: Schritt 4, Bild 1 von 1
    • Place the new BLU Grand M2 power button in the socket.
Abschluss
Alan Rodriguez
311 Reputation
2 Anleitungen geschrieben
Gateway, Team S1-G3, Luster Fall 2018 Mitglied von Gateway, Team S1-G3, Luster Fall 2018
GCC-LUSTER-F18S1G3
4 Mitglieder
4 Anleitungen geschrieben
Ein Kommentar
Don’t forget to remove the SIM card
Jonathan - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 16
Insgesamt: 358
