Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the back cover by lifting at the notch towards the bottom of the phone. Use your fingernail to pry up. Remove the back cover by lifting at the notch towards the bottom of the phone. Use your fingernail to pry up. Remove the back cover by lifting at the notch towards the bottom of the phone. Use your fingernail to pry up.
    • Remove the back cover by lifting at the notch towards the bottom of the phone. Use your fingernail to pry up.
  2. Remove these nine screws with a small philips screwdriver. They are all of the same size There is a small screw hidden under the warranty sticker. You may either remove or poke through it. *WARNING* by doing this you will void your manufacturer warranty.
    • Remove these nine screws with a small philips screwdriver. They are all of the same size
    • There is a small screw hidden under the warranty sticker. You may either remove or poke through it.
    • *WARNING* by doing this you will void your manufacturer warranty.
  3. EINFACH ALLE TABS ÖFFNEN
    RAM Upgrade Kits für Mac
    Kits kaufen
    Genügend RAM
    für alle Tabs
    Kits kaufen
  4. Use the Spudger to gently separate the panel from the frame,  starting from the bottom  left corner. Then work your way along the edges of the phone. Then work your way along the edges of the phone.
    • Use the Spudger to gently separate the panel from the frame, starting from the bottom left corner.
    • Then work your way along the edges of the phone.
  5. Continue using the spudger around the back panel of the phone to separate both pieces. Once you have gone around the entire frame, use both hands to pull it apart. Once you have gone around the entire frame, use both hands to pull it apart.
    • Continue using the spudger around the back panel of the phone to separate both pieces.
    • Once you have gone around the entire frame, use both hands to pull it apart.
  6. Use a pair of tweezers to grab the speaker assembly from the back of the panel and gently remove the it from the frame. (double sided tape is used to hold it together) Install the new speaker, and follow the guide in reverse to reassemble the phone.
    • Use a pair of tweezers to grab the speaker assembly from the back of the panel and gently remove the it from the frame. (double sided tape is used to hold it together)
    • Install the new speaker, and follow the guide in reverse to reassemble the phone.
Abschluss
Julio
695 Reputation
6 Anleitungen geschrieben
Gateway, Team 1-5, Johnson Fall 2014 Mitglied von Gateway, Team 1-5, Johnson Fall 2014
GCC-JOHNSON-F14S1G5
3 Mitglieder
where can i get the Loud speaker
Shamar Houston - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 221
