Zum Hauptinhalt wechseln
Blu Studio 5.5 S Battery Replacement
  1. Blu Studio 5.5 S Battery Replacement, Back Casing: Schritt 1, Bild 1 von 1
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Blu Studio 5.5 S Battery Replacement, Applying Pressure: Schritt 2, Bild 1 von 3 Blu Studio 5.5 S Battery Replacement, Applying Pressure: Schritt 2, Bild 2 von 3 Blu Studio 5.5 S Battery Replacement, Applying Pressure: Schritt 2, Bild 3 von 3
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
  3. Blu Studio 5.5 S Battery Replacement, Battery: Schritt 3, Bild 1 von 3 Blu Studio 5.5 S Battery Replacement, Battery: Schritt 3, Bild 2 von 3 Blu Studio 5.5 S Battery Replacement, Battery: Schritt 3, Bild 3 von 3
    • Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it.
    • Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Cody Dyl
804 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 4-8, Miles Fall 2014 Mitglied von UMass Dartmouth, Team 4-8, Miles Fall 2014
UMASSD-MILES-F14S4G8
2 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 15
Insgesamt: 6,166
