Einleitung
You don't always have to go to your carrier to install your SIM card. Installing a SIM card is a relatively easy process. Follow this guide on how to change or install a SIM card for the BLU Studio 6.0 HD.
  1. Begin by making sure your Blu Studio is turned off.
    • Begin by making sure your Blu Studio is turned off.
  2. To begin the removal of your back panel, first locate the lift tab on the bottom-right corner. To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
    • To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Next, gently slide your thumb (or plastic tool if you prefer) down the seem running the length of your Blu Studio until the rear panel is completely removed. Your rear panel should be placed nearby and in a safe location until you are finished with your task.
    • Next, gently slide your thumb (or plastic tool if you prefer) down the seem running the length of your Blu Studio until the rear panel is completely removed.
    • Your rear panel should be placed nearby and in a safe location until you are finished with your task.
  5. Look at the sticker on top of the battery housing and note the model, part number and type.
    • Look at the sticker on top of the battery housing and note the model, part number and type.
    • Research this information to find out if you have an unlocked version of the phone.
    • If your phone is unlocked you can use any mobile network SIM card. If not you must replace the SIM card with a card from your carrier.
  6. If necessary slide the unneeded SIM card out of it's slot. Make sure your new SIM card has been activated by the carrier. Take the front end tip of the SIM card (the side with the corner cut) and slide it gently into the SIM card slot.
    • If necessary slide the unneeded SIM card out of it's slot.
    • Make sure your new SIM card has been activated by the carrier.
    • Take the front end tip of the SIM card (the side with the corner cut) and slide it gently into the SIM card slot.
  7. Turn on your Studio 6.0 and test it to make sure that everything is working.
    • Turn on your Studio 6.0 and test it to make sure that everything is working.
    • If your phone gives you an error, check your SIM card installation. If everything seems to be correct make sure your SIM card is activated.
    • If everything is working you're good to go.
Abschluss
7 weitere Nutzer haben diese Anleitung absolviert.
Alec
593 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 9-1, Blackwell Fall 2014 Mitglied von USF Tampa, Team 9-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G1
3 Mitglieder
8 Anleitungen geschrieben
Okay so my Sim has been working for months just 2 days ago my phone wouldn't turn on and then we'll now it doesn't read the Sim card idk what's going on with this but its getting annoying
caitlin - Antwort
i know i am having the same issue. it is saying my sim card is off and to turn it on
jsllndr84 -
Its saying my Sim card is off..how do I turn it on.
victor ayitey - Antwort
I just got this phone and I install the sim card like they say and it still says no sim card
Cheryl Dean - Antwort
I have activated metro pcs sim. Unlocked blu studio g2 6.0 will not detect sim wtf?
Tim - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 3
Letzte 7 Tage: 24
Letzte 30 Tage: 125
Insgesamt: 41,656
