Zum Hauptinhalt wechseln
Blu Studio Selfie Battery Replacement
Was du brauchst
  1. Blu Studio Selfie Battery Replacement, Rear Cover: Schritt 1, Bild 1 von 1
    • Make sure your phone is powered off.
    • Turn the front of the phone away from you.
    • Run your fingers along the sides of the phone to identify where the case can be pulled apart.
  2. Blu Studio Selfie Battery Replacement: Schritt 2, Bild 1 von 1
    • Insert the flat end of your plastic opening into the crevice you found along the side of the phone.
    • Gently apply pressure until you feel the back case pop free of the phone.
    • Continue the previous two steps around the rest of the phone until the case is fully removed.
  3. Blu Studio Selfie Battery Replacement, Battery: Schritt 3, Bild 1 von 2 Blu Studio Selfie Battery Replacement, Battery: Schritt 3, Bild 2 von 2
    • Identify the crevice at the bottom of the battery.
    • There should be enough space for you to fit your fingernail between the battery and the phone.
    • Gently lift the battery free of the phone.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Stacy Kam
630 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 10-1, Remmell Spring 2016 Mitglied von USF Tampa, Team 10-1, Remmell Spring 2016
USFT-REMMELL-S16S10G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 1,324
