Zum Hauptinhalt wechseln
Blu Studio Selfie Midframe Replacement
Was du brauchst
  1. Blu Studio Selfie Midframe Replacement, Rear Cover: Schritt 1, Bild 1 von 1
    • Make sure your phone is powered off.
    • Turn the front of the phone away from you.
    • Run your fingers along the sides of the phone to identify where the case can be pulled apart.
  2. Blu Studio Selfie Midframe Replacement: Schritt 2, Bild 1 von 1
    • Insert the flat end of your plastic opening into the crevice you found along the side of the phone.
    • Gently apply pressure until you feel the back case pop free of the phone.
    • Continue the previous two steps around the rest of the phone until the case is fully removed.
  3. Blu Studio Selfie Midframe Replacement, Battery: Schritt 3, Bild 1 von 2 Blu Studio Selfie Midframe Replacement, Battery: Schritt 3, Bild 2 von 2
    • Identify the crevice at the bottom of the battery.
    • There should be enough space for you to fit your fingernail between the battery and the phone.
    • Gently lift the battery free of the phone.
  4. Blu Studio Selfie Midframe Replacement, Midframe: Schritt 4, Bild 1 von 1
    • Remove all the 4mm Phillips #000 screws from the midframe.
  5. Blu Studio Selfie Midframe Replacement: Schritt 5, Bild 1 von 1
    • Insert the spudger between the midframe and the display assembly.
    • Gently pry up the midframe.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
  6. Blu Studio Selfie Midframe Replacement: Schritt 6, Bild 1 von 1
    • Where the battery rested before, you will find a small clip that holds down the midframe.
    • After the rest of the midframe is detached, from the phone place the flat end of the spudger beneath the clip.
    • Gently lift up on the clip until it comes free.
    • Remove the midframe from the phone.
Ziellinie
2 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 10-1, Remmell Spring 2016 Mitglied von USF Tampa, Team 10-1, Remmell Spring 2016
USFT-REMMELL-S16S10G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 446
