Einleitung
Use this guide to replace the rear cover of the BLU Studio Selfie.
Was du brauchst
Turn the front of the phone away from you.
Run your fingers along the sides of the phone to identify where the case can be pulled apart.
Insert the flat end of your plastic opening into the crevice you found along the side of the phone.
Gently apply pressure until you feel the back case pop free of the phone.
Continue the previous two steps around the rest of the phone until the case is fully removed.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
