Einleitung
Is your Blue Yeti is tired, the USB is sometimes capricious, or it simply turns on but is not recognized by the computer? Here is surely the solution to your problem.
Was du brauchst
Defective part to be replaced
Just test it with a multimeter in sound mode.
If the beep is continuous, the problem lies elsewhere.
If the multimeter does not beep, or jerks, the component should be changed.
To reassemble your device, follow the instructions in reverse order.
100%
Corbanizer hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
