Einleitung
Demonstrate the tear-down process and the removal of a broken speaker in the Bolide Technology Group Dual Alarm Clock, so that others looking to replace the speaker have a basis to build from.
Was du brauchst
Remove the batteries on the bottom of the radio
Locate and remove the five screws on the bottom of the radio with a Philips Head Screwdriver.
Grab your nylon pry tool and wedge it between the outer case and the top of the radio. Slowly pry open the top and remove it.
In diesem Schritt verwendetes Werkzeug:Spudger$2.99
Using a black nylon spudger to carefully break the glue around the outside of the speaker so it can be dislodged.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Locate the speaker plug for the speaker you wish to remove and slightly tug on it until it becomes unplugged
After the speaker cord is removed, pull the speaker straight up and out of the radio.
Once the speaker is removed, the inside of the dual alarm clock should look identical to the photo shown.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
