Zum Hauptinhalt wechseln
Bomann DB 774CB Iron
Was du brauchst
  1. Bomann DB 774CB Iron, Startup: Schritt 1, Bild 1 von 1
    • Locate and extract the small plug (circled in the photo) and remove the screw hidden underneath.
    • Unscrew and remove the back plate.
  2. Bomann DB 774CB Iron, Undressing the handle: Schritt 2, Bild 1 von 3 Bomann DB 774CB Iron, Undressing the handle: Schritt 2, Bild 2 von 3 Bomann DB 774CB Iron, Undressing the handle: Schritt 2, Bild 3 von 3
    • Unclip the top of the handle from the back (clips circled in the photos).
    • Unclip the top of the handle from the front (clips circled in the photo). Be careful not to break (like us) the steam nozzle!
    • Pull out the steam control knobs.
    • Carefully "tear" the temperature adjustment knob.
  3. Bomann DB 774CB Iron, Stripping of the sole: Schritt 3, Bild 1 von 2 Bomann DB 774CB Iron, Stripping of the sole: Schritt 3, Bild 2 von 2
    • Remove the screws and remove the plastic shell.
    • Unscrew the screws and remove the base cover.
  4. Bomann DB 774CB Iron, Breakdowns: Schritt 4, Bild 1 von 1
    • Two different failures already observed:
    • Spacer (circled) which had come out of its housing following a fall of the iron!
    • Small foreign body that got stuck between the two contacts (circled).
    • Be careful not to turn the temperature adjustment screw (arrow) located in the control rod. Its readjustment is quite tedious, by mistake and trials!
Abschluss
Putting each screw back in its place is no problem.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
fr en
100%
HelloMacOS hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
Louis Possoz
435 Reputation
3 Anleitungen geschrieben
Repair Café Louvain-la-Neuve Mitglied von Repair Café Louvain-la-Neuve
Local Repair Groups
2 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
Do you instructions in English
Nur Haque - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 56
Insgesamt: 2,976
