Einleitung
Good bearings are essential for smooth ride. This guide will help you take out and replace the skateboard bearings on the rear or front wheels of your Boosted Board. You can choose to replace the bearings with new ones, or just clean the existing bearings.
Was du brauchst
Loosen the two 16.74 mm motor mount hex nut screws with a 9/64" Allen wrench.
Compress the motor mount back towards the wheel.
While keeping the motor mount compressed, tighten one of the hex nuts that you loosened in the previous step.
Rotate and pull counterclockwise until the wheel comes off the axle completely.
Remove the back washer from the axle.
Use an Allen wrench to apply pressure to the inside edge of the bearing until it pops out
Replace bearing by dropping it in the center of the wheel and use a socket wrench to pop in back it place
Slide the bearing spacer on to an Allen wrench
Align the Allen wrench in the center of the bearing and drop the spacer directly in the middle
To reassemble your device, follow these directions in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
