Zum Hauptinhalt wechseln
Bosch 3727DEVS Governor Replacement
Was du brauchst
  1. Bosch 3727DEVS Governor Replacement, Governor: Schritt 1, Bild 1 von 3 Bosch 3727DEVS Governor Replacement, Governor: Schritt 1, Bild 2 von 3 Bosch 3727DEVS Governor Replacement, Governor: Schritt 1, Bild 3 von 3
    • Ensure that the power chord is not plugged into an outlet.
    • Using the T20 Torx Screwdriver, remove the four 15.6 mm screws securing the top cover to the sander.
    • Lift the top off of the sander.
  2. Bosch 3727DEVS Governor Replacement: Schritt 2, Bild 1 von 3 Bosch 3727DEVS Governor Replacement: Schritt 2, Bild 2 von 3 Bosch 3727DEVS Governor Replacement: Schritt 2, Bild 3 von 3
    • Using the T20 Torx Screwdriver, remove the two 15.6 mm screws securing the cable clip to the motor housing.
    • Lift the cable clip and cord from motor housing.
  3. Bosch 3727DEVS Governor Replacement: Schritt 3, Bild 1 von 1
    • Lift the On/Off switch out of the device
    • Remove the gray and purple wires
  4. Bosch 3727DEVS Governor Replacement: Schritt 4, Bild 1 von 2 Bosch 3727DEVS Governor Replacement: Schritt 4, Bild 2 von 2
    • Remove the gray, brown, and clear wires by pulling on the wire terminals.
    • Lift the Governor out of the housing.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 13
Insgesamt: 601
