Einleitung
Purchase a new Power Cord. The sander should be unplugged from any power sources. Make sure you organize the removed screws, so you can reinstall them in the correct location.
Was du brauchst
Using the T20 Torx Screwdriver, remove the four 15.6 mm screws securing the top cover to the sander.
Lift the top cover off the sander.
Using the T20 Torx Screwdriver, remove the two 15.6 mm screws securing the cable clip to the motor housing.
Lift cable clip and cord from motor housing.
In diesem Schritt verwendetes Werkzeug:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Using the 2.5 mm Flathead Screwdriver, loosen the two screws securing the white and black wires to the On/Off Switch.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
