Einleitung
This guide will allow you to access the subwoofers on either side of the Bose Cinemate 10. By removing the end caps, you can clean them or replace the subwoofers.
Was du brauchst
Using the blue plastic opening tool, pry up on the cloth covered end panel. The edge of end cap cover should separate from main body of device.
Using your fingers, lift up on the end cap cover until it separates completely from the main body of the device.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
