Zum Hauptinhalt wechseln
Bose On-Ear headphones Ear Cushion Replacement
Was du brauchst
  1. Bose On-Ear headphones Ear Cushion Replacement, Ear Cushion: Schritt 1, Bild 1 von 3 Bose On-Ear headphones Ear Cushion Replacement, Ear Cushion: Schritt 1, Bild 2 von 3 Bose On-Ear headphones Ear Cushion Replacement, Ear Cushion: Schritt 1, Bild 3 von 3
    • Here is the Bose Tricore OE headset. Slightly worn and a torn left ear cushion
    • To remove an existing ear cushion one would simply be applying a bit of force between the ear pads and the housing. The ear cushion will simply snap off
    • This shows the snaps that attach the ear pad to the case.
  2. Bose On-Ear headphones Ear Cushion Replacement: Schritt 2, Bild 1 von 3 Bose On-Ear headphones Ear Cushion Replacement: Schritt 2, Bild 2 von 3 Bose On-Ear headphones Ear Cushion Replacement: Schritt 2, Bild 3 von 3
    • Since the ear cushion was already torn off on this one, simply clean the mating surfaces from all debris left by the old ear cushion
    • All left over foam and adhesive tape needs to be removed. This will ensure a proper fit.
    • Here is a look at the back of the replacement cushion.
  3. Bose On-Ear headphones Ear Cushion Replacement: Schritt 3, Bild 1 von 3 Bose On-Ear headphones Ear Cushion Replacement: Schritt 3, Bild 2 von 3 Bose On-Ear headphones Ear Cushion Replacement: Schritt 3, Bild 3 von 3
    • Position the cushion so that the orientation aligns the two holes with the two pins on the headphones.
    • Place the new ear cushion on the headphones ensuring the holes and pins are lined up.
    • A simple squeeze on the ear cushion will snap the plastic to the headphones.
  4. Bose On-Ear headphones Ear Cushion Replacement: Schritt 4, Bild 1 von 1
    • Good as new and ready to jam!
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
oldturkey03
815.982 Reputation
119 Anleitungen geschrieben
Global Fixers Mitglied von Global Fixers
Community
46 Mitglieder
708 Anleitungen geschrieben
1 Kommentar zur Anleitung
Thanks for showing the steps
Rajiv Garg - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 29
Insgesamt: 7,795
