Einleitung
These steps will outlines replacement of the QC25 Motherboard, one of which is located in each earpiece. Be warned, this guide requires precision soldering of very small components and not recommended for the faint of heart.
Was du brauchst
Begin repair by removing the ear cushion.
The cushion is held on by a few small plastic clips. Pry carefully with plastic opening tool or fingernails.
Next, remove the soft lining behind the cushion. This is held on with adhesive and is easily removed by hand.
Once the soft lining is removed from behind the ear cushion, two screws will be exposed.
Carefully remove the two 5 mm screws with a precision screwdriver (PH00) and put aside.
Flip the earphones back over and carefully pry around the outside cover of the earpiece.
Try a plastic opening tool before moving on to harder metal tools.
This cover will come loose with moderate pressure.
There are 3 screws holding the motherboard to the earpiece.
Remove these screws to make the next step easier.
Once the motherboard is exposed, all of the soldered connection will need to be removed.
After removing all the soldered joints, the motherboard can be removed by hand.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
