Zum Hauptinhalt wechseln
Bose Solo 5 Sound Bar Control Panel Replacement
Was du brauchst
  1. Bose Solo 5 Sound Bar Control Panel Replacement, Control Panel: Schritt 1, Bild 1 von 1
    • Lay Bose Solo 5 with speakers facing away from you and bottom side facing upward.
  2. Bose Solo 5 Sound Bar Control Panel Replacement: Schritt 2, Bild 1 von 2 Bose Solo 5 Sound Bar Control Panel Replacement: Schritt 2, Bild 2 von 2
    • Remove the five 18.25mm screws with the Phillips #2 screw driver.
  3. Bose Solo 5 Sound Bar Control Panel Replacement: Schritt 3, Bild 1 von 1
    • Remove the gold plates snap connector from the circuit board by pulling it apart.
  4. Bose Solo 5 Sound Bar Control Panel Replacement: Schritt 4, Bild 1 von 1
    • Using the plastic opening tool, lift the circuit board up and remove from housing.
  5. Bose Solo 5 Sound Bar Control Panel Replacement: Schritt 5, Bild 1 von 2 Bose Solo 5 Sound Bar Control Panel Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the cords running to the white connecter by pulling up on the tab until it is disconnected completely.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Emma
500 Reputation
3 Anleitungen geschrieben
Sam Houston State, Team S15-G7, Blackburne Fall 2018 Mitglied von Sam Houston State, Team S15-G7, Blackburne Fall 2018
SHSU-BLACKBURNE-F18S15G7
2 Mitglieder
4 Anleitungen geschrieben
5 Kommentare
Does anyone know where to buy a replacement logic board? I’ve been searching for a while now, no dice.
Tyler Barney - Antwort
hallo und wo bekomme ich das Ersatzteil die Platiene 73252 Delta 3
APP TISCHNER - Antwort
Has anyone had any luck finding the same board. Im looking.
ka.wells - Antwort
I know how to open it. What I don't know is where to buy one.
szanti - Antwort
If anyone was able to find the board, it wuold be great to know where did you find it. Looking for this board during months...
Juan Ramirez - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 29
Letzte 30 Tage: 114
Insgesamt: 12,763
