Einleitung
This is a step-by-step guide to replacing the indicator light on a Bose Solo 5 Sound Bar (Model # 732522-1110). The Indicator light on this speaker will show when the system is on, and shows the status of the system when in operation. The repair process is classified as a moderate difficulty, and does not require any specialized skills.
Was du brauchst
Lay the Bose Solo 5 on its side, with the speakers facing away from you. This orientation will result in the bottom of the speaker facing upwards.
Gently remove the gold plates and the snap connector from the circuit board by pulling it apart.
Using the plastic opening tool, slightly lift the circuit board up and remove it from the housing.
Disconnect the cords running to the white connector by pulling upon the tab until it is disconnected completely.
Locate the two clear LED receptors and note that one has two prongs and the other has three prongs.
Locate on the back of the control panel where it states LED 902, 903, 904, and 905.
If there is any debris located in these locations, use the spudger tool to thoroughly clean the area.
To reassemble the sound bar, follow the steps listed above in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
