Einleitung
The explanations will detail how to remove the bottom plate, revealing the logic board as well as removing the proper attachments and screws. The proper knowledge of how to use a soldering iron is needed when dealing with this component. The following steps will help you find success in replacing the logic board, if needed.
Was du brauchst
After removing the bottom plate, you will have visibility of the logic board. Using a plastic opening tool, lift the small black latch holding the ribbon cable. Slide the ribbon cable loose from the logic board.
Next, using pointed nose tweezers, remove the 4-wire white connector from the logic board by wiggle back and forth while lifting until the connector is disconnected from the board.
Remove the remaining 8mm length # 2 Phillips head screws holding the motherboard in place.
In diesem Schritt verwendetes Werkzeug:Desoldering Pump$3.99
Using a hot soldering iron and either a solder sucker or de-soldering wick, remove the solder from the 6 wires highlighted on the photo in red.
Replace old logic board with the new logic board. Place the wires into the solder holes and solder in place. Reassemble the SoundDock.
To reassemble your device, follow these instructions in reverse order. With proper execution of these steps, you will be able to replace your logic board and enjoy the sound of your SoundDock XT.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
