Zum Hauptinhalt wechseln
Bose SoundTouch Portable Motherboard Replacement
Was du brauchst
  1. Bose SoundTouch Portable Motherboard Replacement, Speaker Battery: Schritt 1, Bild 1 von 1
    • Remove the two T-10 machine screws at the bottom of the device.
  2. Bose SoundTouch Portable Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Turn the device around.
    • From the top, lightly push down the back cover to release it.
    • Lift the bottom of the cover and pull it up.
  3. Bose SoundTouch Portable Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the two T-10 machine screws, then pull the battery straight out.
  4. Bose SoundTouch Portable Motherboard Replacement, Metal Trim: Schritt 4, Bild 1 von 1
    • Remove the two screws using a torx screwdriver.
  5. Bose SoundTouch Portable Motherboard Replacement: Schritt 5, Bild 1 von 1
    • With the bottom of the device facing you, pull down the trim pieces to remove from the device body.
  6. Bose SoundTouch Portable Motherboard Replacement, Motherboard: Schritt 6, Bild 1 von 2 Bose SoundTouch Portable Motherboard Replacement, Motherboard: Schritt 6, Bild 2 von 2
    • Remove four T-10 Torx screws; there are two on the front and two on the back.
  7. Bose SoundTouch Portable Motherboard Replacement: Schritt 7, Bild 1 von 3 Bose SoundTouch Portable Motherboard Replacement: Schritt 7, Bild 2 von 3 Bose SoundTouch Portable Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Pinch and remove the connectors.
    • Use a flat tool to pry off the top piece.
  8. Bose SoundTouch Portable Motherboard Replacement: Schritt 8, Bild 1 von 3 Bose SoundTouch Portable Motherboard Replacement: Schritt 8, Bild 2 von 3 Bose SoundTouch Portable Motherboard Replacement: Schritt 8, Bild 3 von 3
    • Remove the four T-10 Torx screws holding the plastic cover in place.
    • Remove the one T-10 Torx screw that is holding the motherboard in place.
    • Pry off the motherboard.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Chelsea Martin
697 Reputation
6 Anleitungen geschrieben
USF Tampa, Team S1-G3, Leahy Spring 2017 Mitglied von USF Tampa, Team S1-G3, Leahy Spring 2017
USFT-LEAHY-S17S1G3
3 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 19
Insgesamt: 2,931
