Einleitung
This tutorial requires removal of the front grille and back cover to access the speakers.
Was du brauchst
Remove the two T-10 machine screws at the bottom of the device.
Turn the device around.
From the top, lightly push down the back cover to release it.
Lift the bottom of the cover and pull it up.
There are four T-10 Torx screws for each speaker; remove all four screws for each speaker you are replacing.
Using a plastic pry tool, carefully pry the speaker up.
With the bottom of the speaker exposed, unwind the wires from the connection tabs and replace the speaker.
Eine weitere Person hat diese Anleitung absolviert.
