Was du brauchst
Remove the two T-10 machine screws at the bottom of the device.
Turn the device around.
From the top, lightly push down the back cover to release it.
Lift the bottom of the cover and pull it up.
With the bottom of the device facing you, pull down the trim pieces to remove from the device body.
Gently pull on the connectors at the circuit board to remove. Remove the screws from the circuit board and set the board aside.
2 Kommentare
Thanks a lot for sharing your incredible ideas. It is an appreciated and pretty tip for all those music lovers. What a Fatal post for those who want to upgrade an existing subwoofer with a new one.
About more: www.outdoorsumo.com
About more: ++https://compactcarsubwoofer.blogspot.com...
