Zum Hauptinhalt wechseln
Bose Soundlink Flex Battery Replacement
Was du brauchst
    • lay the speaker flat onto its back.
    • use your heat gun to soften the adhesive that holds the grill in place.
    • using your flat head screwdriver, carefully pry up on the grill on all sides.
    • be very careful not to pry into the speaker and radiator.
    • when replacing the grill, reapply the adhesive.
    • leave the grill to one side
    • using your philips head screwdriver, unscrew the 6 screws holding the speaker assembly in place.
    • using your heat gun, apply heat to the edges to again soften the adhesive seal.
    • using your flat head screwdriver, carefully pry up into the speaker's body.
    • be very careful when prying, as the speaker is still attached to wires on the motherboard.
    • when separating the speaker, carefully pull on the connectors on it
    • when putting the speaker assembly back together, again, replace the adhesive on the speaker and body.
    • using your phillips head screwdriver, unscrew all the screws that are attached to the motherboard.
    • using your flat head screwdriver, carefully pry the motherboard out.
    • be very careful of the wires that are still attached to the battery.
    • carefully pry into the connector on the motherboard connected to the battery.
    • Do not pry into the connector too much or you could damage the connector.
    • take the battery out of its slot.
    • take a pair of scissors and carefully cut open the foam casing just enough to take out the battery.
    • be very careful not to accidentally puncture the battery.
    • replace the battery.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
776831
1.095 Reputation
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 33
Letzte 30 Tage: 215
Insgesamt: 2,016
