Was du brauchst
Using a 2.5 mm hex wrench, remove the two 13 mm screws from the bottom of the speaker.
Push up on the back of the cover until it slides up slightly.
Pull the cover up and away from the speaker backing.
Using the screwdriver with the T-10 star tip, remove the 6.75 mm. screws marked in red.
15 weitere Personen haben diese Anleitung absolviert.
11 Kommentare
Where i can buy one them battery model?
Just ordered a “Used, in good shape”, and it seems to be, however, it’s the REALLY original model, with the solid flap on the front, that turns into the stand. SN: 054867920870604AE. Guessing this is NOT the “Soundlink II”, but the original model. Instructions that came with it claim battery will last up to 3 hours. JUST IN CASE this battery is shot, was looking into what’s involved to replace it. However, mine being older, wondering if this battery would still fit?
Thanks, Bob.
How do I get a used replacement battery for this in Nigeria? Please contact me on johnpaulokenyodo@gmail.com if any. Thanks
How much the battery only
