Zum Hauptinhalt wechseln
Bose Soundlink II Battery Replacement
Was du brauchst
  1. Bose Soundlink II Battery Replacement, Bose Soundlink II Cover Removal: Schritt 1, Bild 1 von 1
    • Using a 2.5 mm hex wrench, remove the two 13 mm screws from the bottom of the speaker.
  2. Bose Soundlink II Battery Replacement: Schritt 2, Bild 1 von 1
    • Push up on the back of the cover until it slides up slightly.
    • Pull the cover up and away from the speaker backing.
  3. Bose Soundlink II Battery Replacement, Battery: Schritt 3, Bild 1 von 1
    • Using the screwdriver with the T-10 star tip, remove the 6.75 mm. screws marked in red.
  4. Bose Soundlink II Battery Replacement: Schritt 4, Bild 1 von 2 Bose Soundlink II Battery Replacement: Schritt 4, Bild 2 von 2
    • Carefully remove the battery by pulling it out of the speaker.
Abschluss
14 weitere Personen haben diese Anleitung absolviert.
Kevin Bailey
464 Reputation
2 Anleitungen geschrieben
Texas Tech, Team 22-4, Rauch Fall 2015 Mitglied von Texas Tech, Team 22-4, Rauch Fall 2015
TTU-RAUCH-F15S22G4
3 Mitglieder
3 Anleitungen geschrieben
11 Kommentare
Where i can buy one them battery model?
Daniel Campos - Antwort
Just ordered a “Used, in good shape”, and it seems to be, however, it’s the REALLY original model, with the solid flap on the front, that turns into the stand. SN: 054867920870604AE. Guessing this is NOT the “Soundlink II”, but the original model. Instructions that came with it claim battery will last up to 3 hours. JUST IN CASE this battery is shot, was looking into what’s involved to replace it. However, mine being older, wondering if this battery would still fit?
      Thanks, Bob.
bobveitch4 - Antwort
How do I get a used replacement battery for this in Nigeria? Please contact me on johnpaulokenyodo@gmail.com if any. Thanks
Okenyodo Johnpaul - Antwort
I bought an Replacement battery which brand is Emaks from Amazon and do it following the guide,It works well now!Thank you!!!
Emily - Antwort
How much the battery only
Joboy De Guzman II - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 76
Letzte 30 Tage: 260
Insgesamt: 32,507
