Einleitung
The Bose Soundlink II is a compact Bluetooth speaker requiring substantial disassembly in order to access the components of the device. The side covers are easy to remove if the location of the necessary screws is known.
Was du brauchst
Using a 2.5 mm hex wrench, remove the two 13 mm screws from the bottom of the speaker.
Push up on the back of the cover until it slides up slightly.
Pull the cover up and away from the speaker backing.
Remove the black electrical tape in order to reveal the screws attaching the side cover to the main body of the speaker. These screws are on the base of the device.
Using the T-10 star tip screwdriver, remove the two 13 mm screws located on the bottom of the speaker on each side of the battery pack.
Slide the silver side cover down toward the base of the speaker. The silver cover will come off easily.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
