Zum Hauptinhalt wechseln
Bose Soundlink Revolve Bottom Circuit Board Replacement
Was du brauchst
  1. Bose Soundlink Revolve Bottom Circuit Board Replacement, Bottom Circuit Board Access: Schritt 1, Bild 1 von 2 Bose Soundlink Revolve Bottom Circuit Board Replacement, Bottom Circuit Board Access: Schritt 1, Bild 2 von 2
    • Flip speaker over so that the bottom is facing up.
    • Using the blue spudger, lift the gray foam up and slowly peel it off with your hand.
  2. Bose Soundlink Revolve Bottom Circuit Board Replacement: Schritt 2, Bild 1 von 3 Bose Soundlink Revolve Bottom Circuit Board Replacement: Schritt 2, Bild 2 von 3 Bose Soundlink Revolve Bottom Circuit Board Replacement: Schritt 2, Bild 3 von 3
    • Using the screwdriver, unscrew three screws.
    • Detach the bottom cover from the rest of the speaker by pulling the two in opposite directions.
  3. Bose Soundlink Revolve Bottom Circuit Board Replacement: Schritt 3, Bild 1 von 2 Bose Soundlink Revolve Bottom Circuit Board Replacement: Schritt 3, Bild 2 von 2
    • Remove the screw that is above the charging port.
  4. Bose Soundlink Revolve Bottom Circuit Board Replacement: Schritt 4, Bild 1 von 2 Bose Soundlink Revolve Bottom Circuit Board Replacement: Schritt 4, Bild 2 von 2
    • Remove the two screws connecting the motherboard to the bottom cover of the speaker.
    • Remove the bottom cover.
  5. Bose Soundlink Revolve Bottom Circuit Board Replacement, AUX/USB Port: Schritt 5, Bild 1 von 3 Bose Soundlink Revolve Bottom Circuit Board Replacement, AUX/USB Port: Schritt 5, Bild 2 von 3 Bose Soundlink Revolve Bottom Circuit Board Replacement, AUX/USB Port: Schritt 5, Bild 3 von 3
    • Using the blue plastic opening tool, pry up the small black clamp connecting the AUX/USB port to the lower circuit board.
    • Remove the AUX/USB port from the device.
  6. Bose Soundlink Revolve Bottom Circuit Board Replacement, Bottom Circuit Board: Schritt 6, Bild 1 von 1
    • Remove the yellow tape over the location where the ribbon from the central speaker meets the bottom circuit board.
    • Use the blue plastic opening tool to pry up the black latch holding down the ribbon.
    • Remove the motherboard from the device.
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
Brian Butner
861 Reputation
3 Anleitungen geschrieben
USF Tampa, Team S6-G2, Remmell Fall 2017 Mitglied von USF Tampa, Team S6-G2, Remmell Fall 2017
USFT-REMMELL-F17S6G2
4 Mitglieder
4 Anleitungen geschrieben
42 Kommentare
I need the ribbon because it is damage, can you sell one to me?
My email is ttegil@hotmail.com can you send me the way I can buy it.
Kind regards
Gilberto - Antwort
Hello do toi fond thé ribbon because i have thé same problème .
M'y email adresse thualromain44.rt@gmail.com
Thanks you
romain thual -
Hi I need bottom circuit board for bose revolve , could you sale it for me. mail: seawolf1974@mail.ru , delivery to Spain
kindly regards
seawolf1974 - Antwort
I need bottom circuit board for Bose revolve, can I get it available in Nigeria, @sullivaniheme@gmail.com
Sullivan - Antwort
Hey there, I also require the bottom circuit board for my Bose Revolve sam.rowlands@hotmail.com
Sam - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 22
Letzte 30 Tage: 103
Insgesamt: 14,227
