Einleitung
The Bose Soundlink is a very useful speaker, unless the speaker doesn’t work! This guide provides step by step information on properly replacing the revolve speaker. Be sure to pay close attention and use the proper equipment while handling all parts.
Ersatzteile
Keine Ersatzteile angegeben.
Use a plastic opening tool or metal spudger to remove the rubber mount from the bottom of the speaker.
Use a T10 screwdriver to remove the three 10 mm screws from the bottom of the speaker.
Unhook the ribbon conector that connects the bottom cover to the body, then remove the bottom part of the speaker.
Use a TR9 screwdriver to remove the screws from the top of the speaker, and then remove the top part of the speaker along with the motherboard.
Use a T10 screwdriver to remove the four 6 mm screws around the 2 speakers, and remove the speaker units from the body.
Remove the three 25.3mm screws from the bottom part of the speaker body with a T10 Torx screwdriver.
Use a spudger to pry apart the glued section between the speaker panel and the device.
Remove the four 6 mm screws from the top part of the speaker body using a T10 screwdriver.
4 weitere Nutzer haben diese Anleitung absolviert.
