Einleitung
In this guide, details about disassembling the BOSE SOUNDLINK Revolve speaker are included for individuals who need instructions on how to troubleshoot and fix the speaker.
The Bose SOUNDLINK Revolve is a compact Bluetooth speaker that provides premium quality sound while still light and easy enough to carry. This specific example is not functioning as the speaker can’t be turned on. Thus, our team performed an educational disassemble of the device in order to troubleshoot the problem.
Ersatzteile
Keine Ersatzteile angegeben.
Use a plastic opening tool or metal spudger to remove the rubber mount from the bottom of the speaker.
Use a T10 screwdriver to remove the three 10 mm screws from the bottom of the speaker.
Unhook the ribbon conector that connects the bottom cover to the body, then remove the bottom part of the speaker.
Use a TR9 screwdriver to remove the screws from the top of the speaker, and then remove the top part of the speaker along with the motherboard.
Use a T10 screwdriver to remove the four 6 mm screws around the 2 speakers, and remove the speaker units from the body.
Remove the three 25.3mm screws from the bottom part of the speaker body with a T10 Torx screwdriver.
Use a spudger to pry apart the glued section between the speaker panel and the device.
6 weitere Nutzer haben diese Anleitung absolviert.
5 Kommentare
Is it possible to buy a replacement subwoofer? Mine has been dropped and it's only the bass elements that sound distorted, thank you
Subwoofer with sound distorted at my revolver speaker
Im glad to hear . I live in Puerto Rico and the authorized store wants to charge me $169.00 for a replacement. How do i go about this service . Thanks Bert
