Einleitung
Screens often fail or stop displaying properly. Use this guide to remove and replace the screen assembly.
Was du brauchst
Gently pinch and pull on the white ribbon cable to disconnect it from the base.
Wedge the spudger between the top and front panel on the right side of the device.
Push down on the spudger, lifting the front panel away from the top panel until it pops out of the right side.
Repeat for the left side of the device.
Once the panel is released on the left side, wedge the spudger between the top panel and front grill of the device as shown.
Apply pressure and move the spudger upward until the front grill pops out.
Repeat for the right side of the device.
Turn the device around.
Wedge the spudger into the larger part of the gap under the back of the device.
Move the spudger up until the button panel is loose.
Push forward on the back of the button panel to disconnect the panel from the top of the device.
Pull the button panel forward with one hand and push the screen assembly into the device with the other to disconnect the button panel.
Lift the screen assembly upward and pull the white wire strip out of the device.
4 weitere Personen haben diese Anleitung absolviert.
5 Kommentare
Nicely done. Love the details. Just one question - where can I get the replacement screen?
Instructions were PERFECT! Thank you. I found my replacement screen on ebay for $25, took a chance that it would work as stated by the seller. Otherwise I would have thrown the radio away.
How to purchase White wire strip
