Einleitung
Speakers do not last forever. This guide will demonstrate how to remove and replace the speakers on the device.
Was du brauchst
Gently pinch and pull on the white ribbon cable to disconnect it from the base.
Wedge the spudger between the top and front panel on the right side of the device.
Push down on the spudger, lifting the front panel away from the top panel until it pops out of the right side.
Repeat for the left side of the device.
Once the panel is released on the left side, wedge the spudger between the top panel and front grill of the device as shown.
Apply pressure and move the spudger upward until the front grill pops out.
Repeat for the right side of the device.
Remove a total of eight 15mm Phillips #2 screws surrounding each speaker.
6 weitere Personen haben diese Anleitung absolviert.
