Zum Hauptinhalt wechseln
Bose Wave Radio AWR1-1W Speaker Replacement
Was du brauchst
  1. Bose Wave Radio AWR1-1W Speaker Replacement, Base: Schritt 1, Bild 1 von 2 Bose Wave Radio AWR1-1W Speaker Replacement, Base: Schritt 1, Bild 2 von 2
    • Remove the four 19mm Phillips #2 screws from the base of the device.
  2. Bose Wave Radio AWR1-1W Speaker Replacement: Schritt 2, Bild 1 von 3 Bose Wave Radio AWR1-1W Speaker Replacement: Schritt 2, Bild 2 von 3 Bose Wave Radio AWR1-1W Speaker Replacement: Schritt 2, Bild 3 von 3
    • Turn the device over, holding the base on with your thumbs.
    • Hold the device tightly to prevent the base from falling off.
  3. Bose Wave Radio AWR1-1W Speaker Replacement: Schritt 3, Bild 1 von 3 Bose Wave Radio AWR1-1W Speaker Replacement: Schritt 3, Bild 2 von 3 Bose Wave Radio AWR1-1W Speaker Replacement: Schritt 3, Bild 3 von 3
    • Gently lift the top off of the device.
    • Lift in the direction shown to avoid damaging the wires connecting the top and base of the device.
  4. Bose Wave Radio AWR1-1W Speaker Replacement: Schritt 4, Bild 1 von 3 Bose Wave Radio AWR1-1W Speaker Replacement: Schritt 4, Bild 2 von 3 Bose Wave Radio AWR1-1W Speaker Replacement: Schritt 4, Bild 3 von 3
    • Pinch and unplug the white connector from the device.
  5. Bose Wave Radio AWR1-1W Speaker Replacement: Schritt 5, Bild 1 von 3 Bose Wave Radio AWR1-1W Speaker Replacement: Schritt 5, Bild 2 von 3 Bose Wave Radio AWR1-1W Speaker Replacement: Schritt 5, Bild 3 von 3
    • Gently pinch and pull on the white ribbon cable to disconnect it from the base.
  6. Bose Wave Radio AWR1-1W Speaker Replacement: Schritt 6, Bild 1 von 1
    • The base should now be completely detached from the device.
  7. Bose Wave Radio AWR1-1W Speaker Replacement, Front Grill: Schritt 7, Bild 1 von 3 Bose Wave Radio AWR1-1W Speaker Replacement, Front Grill: Schritt 7, Bild 2 von 3 Bose Wave Radio AWR1-1W Speaker Replacement, Front Grill: Schritt 7, Bild 3 von 3
    • Wedge the spudger between the top and front panel on the right side of the device.
    • Push down on the spudger, lifting the front panel away from the top panel until it pops out of the right side.
    • Repeat for the left side of the device.
    • Too much pressure may break the panel, but it should flex slightly before it pops out.
  8. Bose Wave Radio AWR1-1W Speaker Replacement: Schritt 8, Bild 1 von 3 Bose Wave Radio AWR1-1W Speaker Replacement: Schritt 8, Bild 2 von 3 Bose Wave Radio AWR1-1W Speaker Replacement: Schritt 8, Bild 3 von 3
    • Once the panel is released on the left side, wedge the spudger between the top panel and front grill of the device as shown.
    • Apply pressure and move the spudger upward until the front grill pops out.
    • Repeat for the right side of the device.
  9. Bose Wave Radio AWR1-1W Speaker Replacement: Schritt 9, Bild 1 von 1
    • Lift the front grill away from the device.
  10. Bose Wave Radio AWR1-1W Speaker Replacement, Speakers: Schritt 10, Bild 1 von 3 Bose Wave Radio AWR1-1W Speaker Replacement, Speakers: Schritt 10, Bild 2 von 3 Bose Wave Radio AWR1-1W Speaker Replacement, Speakers: Schritt 10, Bild 3 von 3
    • Remove a total of eight 15mm Phillips #2 screws surrounding each speaker.
  11. Bose Wave Radio AWR1-1W Speaker Replacement: Schritt 11, Bild 1 von 3 Bose Wave Radio AWR1-1W Speaker Replacement: Schritt 11, Bild 2 von 3 Bose Wave Radio AWR1-1W Speaker Replacement: Schritt 11, Bild 3 von 3
    • Gently pull each speaker out of the device.
  12. Bose Wave Radio AWR1-1W Speaker Replacement: Schritt 12, Bild 1 von 3 Bose Wave Radio AWR1-1W Speaker Replacement: Schritt 12, Bild 2 von 3 Bose Wave Radio AWR1-1W Speaker Replacement: Schritt 12, Bild 3 von 3
    • Pull the wire connected to the speakers out of the device.
    • You already disconnected this wire from the inside of the device earlier.
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
Cassie Harriman
1.033 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S15-G2, Banghart Spring 2017 Mitglied von Cal Poly, Team S15-G2, Banghart Spring 2017
CPSU-BANGHART-S17S15G2
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 47
Insgesamt: 7,090
