Einleitung
Use this guide to learn how to replace your left and right speaker drivers for the Bowers and Wilkins T7 Bluetooth Speaker.
Was du brauchst
Remove 14mm screws on the front panel with a J1 Phillips head screwdriver.
There are 8 screws in total.
Using the ifixit Opening Tool, carefully pry off the rubber seal around the sides.
Using the ifixit Opening Tool, pry open at the seam found under the rubber seal.
As the cover starts to come off, you can lift up using your hand.
Gently squeeze the internal locking mechanism inside the red and white terminals with either your fingers or a pair of precision tweezers.
While squeezing the internal locking mechanism, pull back the terminal.
Repeat this process for the second speaker.
Remove the 7mm screws around the speaker using a J100 Phillips head screwdriver.
There are 4 screws in total around each speaker.
Now that all the screws are removed, pull straight up on the speaker drive to remove the speaker drive component.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Where do you buy the replacement driver?
Tôi có cùng một câu hỏi? Tôi sẽ phải mua chúng ở đâu.
