Einleitung
Over time, rechargeable batteries lose their ability to recharge. This guide shows you how to replace the battery in a Braun trimmer.
Was du brauchst
Remove any attached trimmer heads by gripping and pulling away from the body.
Insert an opening pick between the top plate and the grey separator.
Slide the opening pick around the perimeter of the plate to release the hidden clips.
Remove the four 7.0mm Torx T6 screws attaching the grey plastic frame to the black plastic casing.
Desolder the four tabs connecting the batteries to the circuit board.
Repeat for the other side of the battery.
22 weitere Nutzer:innen haben diese Anleitung absolviert.
10 Kommentare
What is the name/part nr. of the battery?
Same goes for 5515.
Thanks for the guide :)
Thanks, I was looking how to take apart 5513, similar enough, as far as the battery replacement goes, any rechargeable AAA battery should do. Batteries don’t like the heat from soldering iron, there are kits for welding batteries, another idea is to get cheap battery holder if you can fit it in.
Does the 1.2V Ni-MH AAA 1000mAh battery work, have an older model MGK5280 ?
Thanks.
