Einleitung
It is possible, though honestly rare, for the motor of a trimmer to fail for one reason or another. If changing the batteries does not restore functionality for this model, trying to replace the motor would be the next step.
Was du brauchst
Remove any attached trimmer heads by gripping and pulling away from the body.
Insert an opening pick between the top plate and the grey separator.
Slide the opening pick around the perimeter of the plate to release the hidden clips.
Remove the four 7mm Torx T6 screws attaching the grey plastic frame to the black plastic casing.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
