Einleitung
The charging base wire harness is essential to the function of the Braun Series 7 790cc-7 charging base. Many consumers may discard the charging base if it cannot be used to charge and clean the razor. This can be expensive but by replacing a faulty charging harness the razor can be used with the charging base again. With the use of this Replacement Guide, one can easily change the charging base harness if required.
Was du brauchst
Remove the cleaner cartridge from the charging base.
Depress the 4 tabs while lightly pulling the cover from the base.
Next, depress the 2 molded tabs while still pulling the cover from the base.
Press inward on the side charging port while pulling cover from the base to separate.
Remove charging terminals by inserting a spudger from bottom the and sliding terminals up.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
