Einleitung
A damaged or disconnected motherboard can lead to potential component or entire device failure. One can reference this guide to learn how to successfully remove and replace the motherboard found within the device.
Was du brauchst
To remove the outer casing, use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides of the device.
Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
To remove the inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the top side of the device.
Carefully lift away the housing and replace the broken casing/component. Replace using the new casing.
To remove the motherboard, proceed to unscrew the 3 Phillips #00 bit type, 13mm long screws located on both sides of the motherboard.
Then, proceed to unscrew the 5 Phillips #00 bit type, 9mm long screws located on the face of the charging dock.
Disconnect the two 4-pin auxiliary button register cables connected on both sides of the motherboard.
