Einleitung
Learn how to properly remove a damaged speaker screen in order to replace it.
Was du brauchst
Using a 1.5mm hex screwdriver start unscrewing the 0.6mm screws holding down the front replacement screen
Repeat the unscrewing process for the other 7 screws
Peel off the front screen using your fingers after using the plastic prying tool/spudger
2 weitere Nutzer:innen haben diese Anleitung absolviert.
