Zum Hauptinhalt wechseln
Braven BRV-1s Speaker Cone Replacement
Was du brauchst
  1. Braven BRV-1s Speaker Cone Replacement, Outer Casing: Schritt 1, Bild 1 von 1
    • To remove the outer case, remove 4 phillips screws (Phillips #00 headtype, 9.3mm long)
  2. Braven BRV-1s Speaker Cone Replacement: Schritt 2, Bild 1 von 1
    • Using a metal spudger, gently pry the side of the defective case.
  3. Braven BRV-1s Speaker Cone Replacement: Schritt 3, Bild 1 von 1
    • Still using the metal spudger, continue to work your way around the outer case.
  4. Braven BRV-1s Speaker Cone Replacement: Schritt 4, Bild 1 von 1
    • Remove the broken outer case. Replace with used/new out case.
    • Note that unless properly sealed with glue, the speaker will no longer be water resistant.
  5. Braven BRV-1s Speaker Cone Replacement, Speaker Cone: Schritt 5, Bild 1 von 1
    • To remove the speaker cone plate, remove 10 phillips screws (Phillips #00 headtype, 9.3mm long)
  6. Braven BRV-1s Speaker Cone Replacement: Schritt 6, Bild 1 von 1
    • Using a metal spudger, gently pry the side of the defective speaker cone plate.
    • Remember to pry all around the side of the speaker cone plate.
    • Keep in mind that the adhesive will make it difficult to pry the plate off. To loosen the adhesive, heat the plate with a device such as a hair dryer.
  7. Braven BRV-1s Speaker Cone Replacement: Schritt 7, Bild 1 von 2 Braven BRV-1s Speaker Cone Replacement: Schritt 7, Bild 2 von 2
    • Remove the broken speaker cone plate. Replace with used/new out plate.
Abschluss
Leanne Abel
101 Reputation
1 Anleitung geschrieben
IUPUI, Team S2-G2, Harley Spring 2017 Mitglied von IUPUI, Team S2-G2, Harley Spring 2017
IUPUI-HARLEY-S17S2G2
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 728
