Einleitung
Following this guide will show you how to access and replace the charging port. The Braven BRV-HD Battery Replacement is a prerequisite for this guide.
Was du brauchst
Placing the device on its back with the BRV-HD logo facing up, remove the eight 5mm hexagon 2.0 screws on the front panel.
Placing the device with the back panel facing up, remove the eight 5mm hexagon 2.0 screws from the back panel.
Turning the device on its side, unscrew the four 15mm hexagon 2.0 screws on the charging port panel.
Place the device on its front.
Loosen the four 12mm Phillips screws in the four corners with a J1 screwdriver.
Loosen the two 8mm Phillips screws in the center with a J1 screwdriver.
Remove the four 12mm Phillips screws securing the two battery brackets with a J1 screwdriver.
Use the plastic opening tool to lift up the battery.
Remove the battery using your hands.
Disconnect the three plugs attached to the plastic charging port panel.
Remove and replace the plastic panel with a new one.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
BRV-HD Bluetooth board parts
BRV-HD Bluetooth broad parts
