Einleitung
The following step-by-step guide will show how the power button can be located and replaced. The Braven BRV-HD Battery Replacement is a prerequisite for this guide.
Was du brauchst
Placing the device on its back with the BRV-HD logo facing up, remove the eight 5mm hexagon 2.0 screws on the front panel.
Placing the device with the back panel facing up, remove the eight 5mm hexagon 2.0 screws from the back panel.
Turning the device on its side, unscrew the four 15mm hexagon 2.0 screws on the charging port panel.
Place the device on its front.
Loosen the four 12mm Phillips screws in the four corners with a J1 screwdriver.
Loosen the two 8mm Phillips screws in the center with a J1 screwdriver.
Remove the four 12mm Phillips screws securing the two battery brackets with a J1 screwdriver.
Use the plastic opening tool to lift up the battery.
Remove the battery using your hands.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Disconnect the wire attaching the battery to the motherboard.
Place the device so the blue button panel is facing up, and use a J00 Phillips J1 head screw driver to remove the two 7mm Phillips head screws on either side of the button panel.
