Einleitung
Following this guide will show you how to access and replace the speakers.
Was du brauchst
Placing the device on its back with the BRV-HD logo facing up, remove the eight 5mm hexagon 2.0 screws on the front panel.
Placing the device with the back panel facing up, remove the eight 5mm hexagon 2.0 screws from the back panel.
Turning the device on its side, unscrew the four 15mm hexagon 2.0 screws on the charging port panel.
Place the device on its front.
Loosen the four 12mm Phillips screws in the four corners with a J1 screwdriver.
Loosen the two 8mm Phillips screws in the center with a J1 screwdriver.
Remove the four 12mm Phillips screws securing the two battery brackets with a J1 screwdriver.
Use the plastic opening tool to lift up the battery.
Remove the battery using your hands.
Locate the two wires that connect the right speaker to the motherboard.
Gently disconnect the wires from the motherboard.
Locate the two wires that connect the left speaker to the motherboard.
Position the device facing up and remove eight 10mm Phillips head screws using a J1 Phillips head screwdriver.
Lift the speaker out using the metal spudger and complete lifting by using your hands.
Remove the speakers with your hands and replace with new ones.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
Where can I find a replacement speaker?
Peerless by Tymphany PLS-65F25AL01-02
Alex -
Where can I find or order a replacement speaker for BRV PRO
