Zum Hauptinhalt wechseln
Brentwood TS-292B Bread Grabber Spring Replacement
Was du brauchst
  1. Brentwood TS-292B Bread Grabber Spring Replacement, Bread Grabber Spring: Schritt 1, Bild 1 von 2 Brentwood TS-292B Bread Grabber Spring Replacement, Bread Grabber Spring: Schritt 1, Bild 2 von 2
    • Turn the toaster upside down.
    • Remove the five 6 mm screws with a Phillips #2 screwdriver.
  2. Brentwood TS-292B Bread Grabber Spring Replacement: Schritt 2, Bild 1 von 2 Brentwood TS-292B Bread Grabber Spring Replacement: Schritt 2, Bild 2 von 2
    • Grasp the plastic pull lever cover firmly and pull to remove it. This may require force.
    • Lift the cover upwards to remove it.
    • When removing the cover, do not damage the cable connector bundle that attaches the cover to the toaster.
  3. Brentwood TS-292B Bread Grabber Spring Replacement: Schritt 3, Bild 1 von 1
    • To detach the bundled cable connector, carefully pull it away from the circuit board.
  4. Brentwood TS-292B Bread Grabber Spring Replacement: Schritt 4, Bild 1 von 2 Brentwood TS-292B Bread Grabber Spring Replacement: Schritt 4, Bild 2 von 2
    • Pull the toaster lever down.
    • While holding the toaster lever down, use the spudger to pull the metal tabs away from the wired bread grabber.
    • Continuing to hold the toaster lever down, pinch the wires inward and pull up to carefully remove them from the toaster.
Abschluss
Elly Ayala
739 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 365
